Date/Time: Sat, 23 Nov 2024 19:27:09 +0000
COT data issue - v969
View Count: 2081
[2013-04-30 13:53:43] |
ejtrader - Posts: 688 |
SC Team - Something seems to have changed with v969 causing COT data to be incorrect. This was fine until 968. PS: This is the case with both COT High & COT Low ( though the picture shows issue as COT High only ). it's also the case with PullBack. Thanks Date Time Of Last Edit: 2013-04-30 13:57:23
SC_COT_Issue.png / V - Attached On 2013-04-30 13:53:34 UTC - Size: 4.54 KB - 559 views |
[2013-04-30 17:56:47] |
We will resolve this.
[2013-08-15 10:51:41] |
User77400 - Posts: 2 |
has this issue been resolved?
[2013-08-15 11:01:15] |
Yes of course. It was resolved within one day back on May 1.
