Date/Time: Sat, 23 Nov 2024 08:16:32 +0000
Opening new charts
View Count: 600
[2022-09-21 19:16:23]
User862138 - Posts: 19
Good day,
For some reason, the site where I need to open a new chart chart (under file - open new chart) has completely changed. It does not display the diffrent indexes and markets.
Pls confirm what the problem is or what I should do to rectify.
Regards
DT
[2022-09-21 21:09:54]
There is no option within Sierra Chart for File >> Open New Chart. And if you are selecting File >> Find Symbol then that page has not changed at all.
Therefore, we are not sure what you are referencing in terms of opening a new chart and what has changed. We have made extensive changes to our dialog windows, although not all have changed, mostly the Settings windows. Refer to the following regarding this:
Settings Windows Interface
But again, as noted above, there has not been any changes to the Open dialogs.
[2022-10-02 06:46:28]
Where do I now link the charts I have open (different time scales, volume chart, numbers bars, footprint chart) so that when I change a symbol, all of them changes at the same time?
It is really frustrating to start to learn everything again from the beginning as all was running well until I now wanna change to new symbols, etc.
Thanks and pls confirm if there is a Youtube link one could follow.
[2022-10-02 09:30:51]
JohnR - User831573 - Posts: 306
The ability to link charts is under the Chart menu. You need to do this for each chart you want to link.
1 - Open the Chart menu
2 - Select the Link tab at the top
3 - Select the link # you want to use - It should be the same for each chart
4 - Select what you want to use as the "thing or things" that can cause a change to occur in all of the linked charts
Below is the URL that describes this capability in the docs
Chart Menu: Linking (Chart menu)
Hope this helps,
JohnR
imageSel_Link_multiple charts.png / V - Attached On 2022-10-02 09:30:14 UTC - Size: 58.41 KB - 103 views
[2024-11-13 09:38:26]
User338356 - Posts: 8
Good morning everyone, is it possible to transform an indicator such as Price Volume Trend into a normalised indicator between 0 and 100? Thank you
Date Time Of Last Edit: 2024-11-13 09:39:24
[2024-11-13 17:21:14]
You would have to use the "Spreadsheet Study" to do this and use the MIN() and MAX() functions to find the minimum and maximum values in order to then normalize the data as you want.
Keep in mind the Spreadsheet Study by default, has 1000 rows, so you would need to increase this if you need more. But it would be best to leave it as it is and just normalize the most recent 1000 bars.
