Date/Time: Sat, 23 Nov 2024 08:03:29 +0000
[Programming Help] - ACSIL: Getting the actual name of a Study (by ID)?
View Count: 429
[2022-07-04 16:57:19] |
ycomp - Posts: 316 |
Is there a way to get the Study name (I mean the actual study name, i.e. the sc.GraphName, not the short name) using the ID of a study? I would like to set an input that refers to another study. Then make sure that this study is the correct type of study by comparing the name. But if a shortname is set then it could be anything so there is no way to check for certain using sc.GetStudyName() since it will return the shortname if there is one. |
[2024-11-15 12:04:52] |
User267000 - Posts: 6 |
Hello, I have this problem too, is there any solution ? |
[2024-11-15 14:28:11] |
User431178 - Posts: 540 |
Yes, here are some documented functions: sc.GetBuiltInStudyName sc.GetStudyInternalIdentifier() You could also search in sierrachart.h and see what functions are available, as not all are documented. |
