Date/Time: Fri, 29 Nov 2024 16:39:54 +0000
Trading mini DAX
View Count: 572
[2022-06-22 08:39:23] |
User439112 - Posts: 5 |
Hello I have an account with Dorman Trading and am using Teton via Sierra charts. Is there any way for me to trade eurex mini dax ? Thanks |
[2022-06-22 08:49:46] |
No Teton does not support EUREX trading. You would need to use CQG or Rithmic.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-06-22 08:49:51
[2022-06-22 09:09:08] |
How can I use CQG or Rithmic? Should I change my service package? (I currently use service package 10)
[2022-06-22 16:50:15] |
It is not a matter of changing your service package with us. You are fine on Package 10. The only thing you would need to do with us is to add the EUREX exchange to your Denali Exchange Data Feed. The instructions for this are at the following link: Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges* In order to trade EUREX you have two choices: 1) Create another account with Dorman that would be setup with CQG or Rithmic for your trading service to trade EUREX. You would then need a second installation of Sierra Chart to connect to that account while the first installation will still trade through the Teton Order Routing service for the CME Group. 2) Change your trading service for your current account with Dorman to either CQG or Rithmic, such that you are no longer using the Teton Order Routing Service. You would then just need to change the setup on your current installation of Sierra Chart. Whatever you choose, let us know and we can then direct you to the proper instructions. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-06-22 17:24:01] |
which one is preferred, CQG or Rithmic? Thank you John |
[2022-06-22 18:45:44] |
Either one as far as we are concerned. But you might want to get opinions from other customers. Particularly with regards to EUREX trading.
[2022-06-22 21:34:36] |
tomas262 - Posts: 141 |
Been trading FDAX using CQG. Works very well. DENALI EUREX data is a must!
[2022-06-22 21:40:51] |
Thanks a lot tomas :)
[2023-01-25 21:20:45] |
virtualcointrading - Posts: 39 |
So it is not possible to trade EUREX with Rithmic data (I have full EUREX market depth through them)? We have to purchase Denali data for EUREX? |
[2023-01-25 22:54:26] |
You have to get the EUREX data through us. We do not have support for EUREX except through our Denali Exchange Data Feed. Refer to the instructions here: Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
