Date/Time: Fri, 29 Nov 2024 22:36:47 +0000
How do you change symbols across all charts in chart book?
View Count: 2804
[2022-04-04 05:53:02]
Zen Trader - Posts: 4
What is the easiest way to change your current symbol to another across all charts within your open chartbook?
Thanks.
[2022-04-04 16:16:53]
John - SC Support - Posts: 36350
If you are using the same symbol for multiple charts, then the best thing is to have those charts linked for the symbol. This way, when you change one chart, the others will update. You will have to put the time into creating the linking, but it will be worth it in the end.
Refer to the following for chart linking:
https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#LinkNumber
[2022-04-05 06:21:38]
Thanks that worked well.
One other question if that is okay, say I want to copy study settings from one study to another study on a different chartbook, is there an easy way to do this?
Example: I have Cumulative Delta period lines I would like to cut n paste to a Cumulative Delta on another chartbook with no period lines currently.
[2022-04-05 11:11:46]
For this you will want to use Study Collections:
Study Collections
[2022-04-06 04:10:32]
Thanks for your reply.
I've used the function under studies, save studies as a study collection / save single and ticked prompt to remove existing studies.
I can load this on another chartbook however, it is not translating the line intervals from the original study.
Is there something I could be doing wrong that I should check?
[2022-04-06 14:08:43]
What exactly do you mean by "it is not translating the line intervals from the original study."? What is the study that you are copying?
The Study Collection is going to give you the exact settings as they were when the Study Collection was created. Therefore, unless there is a dependency on the underlying bar data for the output, then you should expect to get the same data when you add the Study Collection.
