Date/Time: Fri, 29 Nov 2024 21:40:46 +0000
Consolidating two columns into one on the Study Summary
View Count: 564
[2021-10-26 03:57:47] |
User606491 - Posts: 164 |
For visual purposes, I would like to include both buy and sell triggers in one column of the Study Summary. For example (if TRIGGER >0, Color study summary background GREEN, if TRIGGER <0, Color study summary background RED, else Color study summary WHITE). Currently, I use two columns - the first to show buy triggers and the second to show sell triggers. Is there a way to consolidate both triggers into one column on the Study Summary so that my column would include both red and green backgrounds? Thanks, |
[2021-10-26 14:51:03] |
There is not a way to do this. To begin with, there is only the one color for the Alert background in the Study Summary. We have marked this as a Feature Request. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-01-10 01:01:34] |
User624595 - Posts: 207 |
Could you consider adding multiple different alert colors to Study Summary?
