Date/Time: Sat, 23 Nov 2024 08:09:56 +0000
Is there any way to always keep a window on top?
View Count: 1105
[2021-08-11 22:54:20] |
SabikiSensei - Posts: 75 |
I've ran out of space on my screen. I just need a small chart window to sit on top of my market profile but always have priority since I still sometimes click on the market profile chart.
[2021-08-12 13:23:24] |
For the chart that you want to "Always be on Top", make it a detached window and then select the option for Window >> Always on Top. Refer to the following regarding Detaching/Attaching a window: Detaching and Attaching Chart Windows And refer to the following regarding "Always on Top": Window, CB and CW Menus: Always on Top (Window) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-11-17 23:16:19] |
User629461 - Posts: 179 |
Would it be possible to have the option to 'Always be on top' within the Main Window workspace and not have to detach?
[2024-11-18 16:06:54] |
There is not an option for "Always on Top" within the main window workspace. It only works with Detached windows.
