Date/Time: Thu, 27 Feb 2025 22:27:44 +0000
DATA PROBLEM
View Count: 413
[2021-08-03 17:55:10] |
rarguedasc - Posts: 1 |
Today in the morning it appears without data, the payment of the platform and the data feed has already been made. https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=53385 |
[2021-08-03 18:21:28] |
John - SC Support - Posts: 38257 |
Ensure that the setting for File >> Data/Trade Service Settings >> Common Settings >> Allow Support for Sierra Chart Data Feeds is set to Yes. From what you show, it looks like this is set to No. After you make a change to that setting, select File >> Disconnect followed by File >> Connect to Data Feed. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
