Date/Time: Thu, 27 Feb 2025 22:11:26 +0000
Text tool Asociation
View Count: 411
[2021-08-03 01:27:31] |
User168596 - Posts: 10 |
Hi... I would like to know if is possible to have a Stationary Tex as Study. I want to have differente Stationary Text when I change the study collection. Regards. |
[2021-08-03 14:28:51] |
John - SC Support - Posts: 38254 |
You can use the Text Display for Study to accomplish this. Just set the Input for Use Text for Non-Zero Value to Yes and then leave the Input for Non-Zero Value Text to blank. Then enter in the text you want in the Prefix Text for Display Value. It doesn't matter what you enter for the Study and Subgraph to Display. Store this study with your Study Collection where the text you enter will be what you want for each Study Collection. Refer to the following for information on the Text Display for Study study: Text Display For Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
