Date/Time: Thu, 27 Feb 2025 22:13:35 +0000
Buy/Sell column Volume bars position
View Count: 479
[2021-08-02 22:59:55]
rtrader101 - Posts: 8
As the title says, I would like to ask if it's possible that I missed the option, but seems like I can not change the Volume bars alignment on Bid Size/Buy and Ask Size/Sell DOM columns.
As the attached picture shows, when I enter the menu "Customize Chart DOMN Columns" and I change the Alignment, for the Pulling and stacking columns, it aligns the text, as well as the volume bars, while for the Bid/Ask size Columns, it aligns only the text.
My OCD is advanced, I know, but I would like to ask if it would be possible to implement that, if it is not already done...
Thank you very much in advance.
Best regards
Radu Calin
imageDOM_Columns.png / V - Attached On 2021-08-02 22:59:06 UTC - Size: 115.13 KB - 170 views
[2021-08-03 13:41:34]
John - SC Support - Posts: 38254
What you are seeing is how it is functioning right now. You can not change the position of the Volume Bars for the main Bid/Ask Size columns. This is something we have on our list of changes, but we do not know when we will be able get to it.
[2021-08-03 15:32:09]
Ok, I understand. Thank you for the answer.
