Date/Time: Thu, 27 Feb 2025 22:29:58 +0000
Sierra/TT Incompatibility
View Count: 544
[2021-08-02 17:41:19] |
Technical - Posts: 158 |
I asked TT about this however they referred me to you. Is there a list of order types that are incompatible with TT Fix? |
[2021-08-02 18:09:03] |
John - SC Support - Posts: 38257 |
Refer to the information here: https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#Included For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
