Date/Time: Thu, 27 Feb 2025 22:31:54 +0000
Setup with Apteros
View Count: 783
[2021-08-02 16:21:03] |
User803948 - Posts: 3 |
Hello, I restarted my tryout with Apteros and they say I'm setup in Sierra Charts, but I'm not able to enter a trade and when I check the "balance' I don't see anything. I'm not sure If I'm doing something wrong? Thank you, Josh |
[2021-08-02 17:30:43] |
John - SC Support - Posts: 38257 |
It doesn't look like you have setup your Trading Evaluator account. First though, update to the current release to ensure that you are on a version that supports the new Evaluator. You can do this using the Fast Update option, the instructions are here: Software Download: Fast Update Then follow these instructions to create your actual Evaluator account: Simulated Futures Trading Service: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
