Date/Time: Thu, 27 Feb 2025 22:30:10 +0000
Unable to connect my Sierra Chart to Denali Exchange Data Feed
View Count: 390
[2021-08-02 16:14:08] |
dluo1688 - Posts: 2 |
Hello, I am Unable to connect my Sierra Chart to Denali Exchange Data Feed. Could you please advise me? Thanks, |
[2021-08-02 17:15:18] |
John - SC Support - Posts: 38257 |
You need to follow through all of the instructions for the Denali Exchange Data Feed. You will find the Setup Instructions for the CME Group data here: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* If you are looking to get data for EUREX or CFE, then go to the top of the above page and select the link for the appropriate Setup Instructions that you are looking for. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
