Date/Time: Thu, 27 Feb 2025 22:22:20 +0000
rithmic DTC
View Count: 464
[2021-08-02 16:13:51]
Trader&Hunter - Posts: 131
I purchased the package 11 so i can use the new rithmic interface. None of my charts will load past june 11th. I followed every direction too.
[2021-08-02 17:13:35]
John - SC Support - Posts: 38256
Are you having a problem with getting the current data or historical data?
Keep in mind that there is limited historical data available from Rithmic. So you will most likely not get the data to fill in from June 11th to today.
But, you should be getting the current - real-time data.
