Date/Time: Thu, 27 Feb 2025 22:35:51 +0000
Volume by Price not showing Bid Volume X Ask Volume correctly after update
View Count: 478
[2021-08-02 14:37:38] |
PaulP - Posts: 1 |
After I updated, the Volume by Price study no longer shows Bid Volume X Ask Volume for price levels that have zero on one side (i.e. 0x100 or 100x0). This can be seen on the top and bottom most levels of the attached screenshot. The relevant study settings are: Display Volume in Bars = Bid Volume x Ask Volume Volume Text Threshold = 0 http://www.sierrachart.com/image.php?Image=1627914854822.png |
[2021-08-02 16:34:08] |
John - SC Support - Posts: 38259 |
We see the issue and will work on a fix. We'll update this thread when we have it fixed.
[2021-08-03 15:44:58] |
We have this fixed, so it will be in the next Pre-Release (v 2294). When it is available, you can update by following these instructions: Software Download: Fast Update For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
