Date/Time: Thu, 27 Feb 2025 22:16:37 +0000
need remote help setting most efficient data feed
View Count: 520
[2021-08-02 11:23:10]
User427561 - Posts: 217
was away a couple weeks need help setting most efficient data feed . now using amptrading cqg acount and SC rev 2280 my phone is xxx-xxxxxxx [phone number removed for privacy] thanks
Date Time Of Last Edit: 2021-08-02 15:44:15
[2021-08-02 15:45:25]
John - SC Support - Posts: 38255
We are not sure exactly what you are wanting help with.
If you need help over the phone, then we recommend Diana Pena who can be found here:
https://www.buymeacoffee.com/dianapena
[2021-08-02 19:02:59]
I nreed help signing up with the correct credwntials. I was away a couple weeks and meanwhily i see a note that cqg is not recommended by SC. i need help withe the data feed acceptable to SC and amp trading as broker, the reference you indicateed charges $50 per call thats newsto me.
Date Time Of Last Edit: 2021-08-02 19:04:09
[2021-08-02 19:49:40]
If you are using AMP for your broker then you will need to use CQG for your order routing. In general, we are not happy with the data from CQG, but the order routing is fine. Therefore, if you are wanting to stay with AMP, then we recommend getting the CQG credentials from AMP (if you do not already have them) and then setting up the Denali Exchange Data Feed for your data.
Therefore, you would follow these instructions to setup your connection to CQG:
CQG Trading Platform Service: Setup Instructions
And then you would follow these instructions to setup the Denali Exchange Data Feed for the CME Group data:
[2021-08-02 20:02:21]
what other broker would you recommend?
[2021-08-02 20:11:49]
In general we recommend using the Sierra Chart Order Routing service. Refer to the information on the following link (and note the list of brokers in Step #2 of the Setup Instructions):
Sierra Chart / Trading Technologies Futures Order Routing Service
