Date/Time: Thu, 27 Feb 2025 22:25:39 +0000
Change display order on default candles?
View Count: 427
[2021-08-01 16:37:45] |
User130862 - Posts: 20 |
To change display order on studies, I do know how. But how do I set that the default chart candles are at bottom and studies on top? Now candles are on top and hides important information. |
[2021-08-02 08:54:39] |
This is controlled by this setting: Chart Studies: Settings and Inputs Tab >> Draw Study Underneath Main Price Graph (in the same Chart Region) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
