Date/Time: Thu, 27 Feb 2025 22:15:47 +0000
Charbook
View Count: 429
[2021-07-31 22:49:54]
Robert Wojczak - Posts: 147
I keep saving a chartbook it saves then when I go to open it its gone and I get the attached message
imagechartbook sierra.PNG / V - Attached On 2021-07-31 22:48:52 UTC - Size: 121.5 KB - 191 views
[2021-08-02 08:48:00]
The problem is you are saving a Chartbook using unsupported characters. Refer to:
Chartbooks (Workspaces): To Save a Chartbook
