Date/Time: Thu, 27 Feb 2025 22:22:26 +0000
Freeze during Chart Replay
View Count: 508
[2021-07-30 18:17:14] |
User138418 - Posts: 16 |
Frequent (almost always) freeze during replay, even with no studies. “SierraChart_64 is not responding…” message requires reload. ESU21-CME, NQU21-CME; Speed immaterial, all fail. Replay Modes: all except ‘Standard’ CPU usage goes from <7% during replay to < 1% during freeze, so no “endless loop”. |
[2021-08-02 10:08:31] |
Therefore, this does not make any sense. Maybe you need to increase the speed of the replay because there is no trading activity to replay based upon the speed you are using. Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-08-02 10:08:48
