Date/Time: Thu, 27 Feb 2025 22:45:05 +0000
Scaling-out problem in V2292 @Engineering
View Count: 452
[2021-07-30 12:56:18]
User754053 - Posts: 15
Dear SierraChart Engineering,
today I updated to the latest version.
So far I have figured out following situation:
A) Scaling out works fine with brackets having a Target and a Stop.
B) Scaling out does not work anymore in V2292 if Bracket only has a stop. (Works in V2288 fine before)
Can you please check this issue?
I have attached the .twconfig file I've used and did not Scale-out at all.
[Disabling and Reenabling Scaling-Out did not succeed. Rolled back to 2288 and issue disappeared]
attachmentS20 -no Auto BE.twconfig - Attached On 2021-07-30 12:49:16 UTC - Size: 4.86 KB - 334 views
[2021-07-30 14:49:18]
We will resolve this today.
[2021-08-02 10:00:55]
You will need to update to the latest prerelease:
