Date/Time: Thu, 27 Feb 2025 22:26:44 +0000
compile gateway time-out.. takes too long?
View Count: 531
[2021-07-30 06:16:14] |
jomo88 - Posts: 47 |
I am trying to compile a code with a 2000 lines, and lots of inputs. The compiling takes so long it times out... Is there any way around this? The remote build did not succeed. Result: <html> <head><title>504 Gateway Time-out</title></head> <body bgcolor="white"> <center><h1>504 Gateway Time-out</h1></center> <hr><center>nginx/1.13.12</center> </body> </html> |
[2021-07-30 06:24:43] |
We are not observing this now. Try the remote build again. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-07-30 06:25:10
[2021-07-30 12:52:07] |
Still happening - started at 08:47:47. It went to 8:48:48 before it gives up. Gives the message below... Allow time for the server to compile the files and build the DLL. The remote build did not succeed. Result: <html> <head><title>504 Gateway Time-out</title></head> <body bgcolor="white"> <center><h1>504 Gateway Time-out</h1></center> <hr><center>nginx/1.13.12</center> </body> </html> -- End of Build -- 08:48:48 |
[2021-07-30 15:49:52] |
We will look into why this Gateway timeout is occurring. It does not make sense.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-07-30 15:50:06
[2021-07-30 21:50:48] |
@jomo88: We have increased the timeout on the service. Please try again now, and let us know how it goes.
Sierra Chart Support |
[2021-08-02 05:24:53] |
It's still not long enough for me... can we try 3 minutes? Build started 00:25:02 Allow time for the server to compile the files and build the DLL. The remote build did not succeed. Result: <html> <head><title>504 Gateway Time-out</title></head> <body bgcolor="white"> <center><h1>504 Gateway Time-out</h1></center> <hr><center>nginx/1.13.12</center> </body> </html> -- End of Build -- 00:27:03 |
[2021-08-02 08:58:02] |
Might be best, that you just use Visual C++ rather than doing a remote build but we will see about increasing the timeout.
