Date/Time: Thu, 27 Feb 2025 22:30:30 +0000
[Programming Help] - Constant Volume Bars Differ From NinjaTrader/Tradovate
View Count: 902
[2021-07-28 08:04:32] |
globaljobber - Posts: 3 |
I have a trial of Sierra at the moment, so have delayed data. I am using 1000 Constant Volume bars in Sierra. I am looking at S&P 500, ES futures contract. I note the bars look slightly different to the bars in both NinjaTrader and Tradovate which I am referencing. Both NT and Tradovate CV bars are identical. What could be the reason for this? Thank you in advance. |
Attachment Deleted. ![]() |
[2021-07-28 12:05:43] |
Sawtooth - Posts: 4177 |
1. Sierra Chart timestamps the bar at the Open, NinjaTrader at the Close. 2. File >> Data/Trade Service Settings >> Common Setting >> Intraday Data Storage Time Unit should be set to 1 Tick. If you change this, you'll need to go to Edit >> Delete All Data And Download 3. There can be some differences in data quality. |
[2021-07-28 14:00:55] |
Thank you tomgilb. Does changing the Data Storage Time Unit affect performance at all? |
[2021-07-28 14:04:40] |
Not that I've noticed
[2021-07-28 14:13:45] |
Last question. What do you mean by 'there can be some differences in data quality' Thanks! |
[2021-07-28 14:36:06] |
Not all data feeds are exactly the same at every tick, especially with volume, bid volume, and ask volume.
Date Time Of Last Edit: 2021-07-28 14:36:21
