Date/Time: Thu, 27 Feb 2025 22:27:04 +0000
Change timing study based on T-1hr
View Count: 456
[2021-07-27 20:04:36]
Ben A - Posts: 123
I wish to run a bands study on the price as it was 1 hour ago and overlay this on my normal chart.
How can I accomplish this please? Thank you for your advice.
Date Time Of Last Edit: 2021-07-27 20:16:28
[2021-07-27 21:03:47]
John - SC Support - Posts: 38257
If we are understanding you correctly, you want to display the Bands from 1 hour previously.
To do this, put the Bands study on your chart and hide it. Then add the Spreadsheet Formula to the chart and enter the following formula:
=ID1.SG1[-60]
Where ID1 is the actual ID of the Bands Study (adjust as necessary) and SG1 is the Subgraph of the Top Band and -60 is the number of bars back for which you want the data (-60 assumes 1 minute bars, if you were using 15 minute bars it would be -4 to get 1 hour back, etc.).
You would then add a second Spreadsheet Formula and use the following formula for the lower band:
=ID1.SG2[-60]
Make sure that both Spreadsheet Formula studies have their Region set to Region 1.
Refer to the following for the Spreadsheet Formula:
Spreadsheet Formula
[2021-07-27 21:17:31]
Ben A - Posts: 123
I struggled to describe what I meant but yes, exactly what I want, thanks John! :)
