Date/Time: Thu, 27 Feb 2025 15:20:28 +0000
HOW TO RESTORE TITLE BAR OF THE CHART
View Count: 1624
[2021-07-13 20:13:51] |
Samuel David - Posts: 22 |
Hi, How do I restore the title bar of a chart that has been detached. That is the (File, Edit, Chart, Analysis, Tools, Spreadsheet, Trade, Global Settings, window, CB, CW, Help). This has disappeared from my chart Appreciate your feedback. Thanks, Samuel |
![]() Attachment Deleted. |
[2021-07-13 20:50:15] |
John - SC Support - Posts: 38222 |
Right-click in the Region Data Line at the top of the graphics area. You will get an option for Show Menu. Select that to get your menu back. From there, if you want the Title Bar back (the top of the window that you would typically grab to move) then go to Chart >> Show Title Bar. Refer to the information here: Chart Menu: Show Menu (Chart menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
