Date/Time: Thu, 27 Feb 2025 15:19:55 +0000
Targets/Stops do not match attached orders when adding
View Count: 527
[2021-07-13 19:10:38]
User397885 - Posts: 5
I notice that after upgrading to the newest version of SC 2280 my targets no longer follow the tick value assigned to the attached orders when using my Trade Window.
I have tested this in live and sim trading. Bascially, when entering a new position, the targets and stops match the attached order. (Ex: enter 2 contracts, both with a stop 16 ticks from entry and T1 20 ticks and T2 40 ticks)
However, if one of the contracts is scaled out of the position, when I go to add a new contract, instead of having a stop 16 ticks from entry and a target 20 ticks from entry, the order is immediately combined to the original order, combining all contracts to a single target.
How can I change this? I want to add to a trade and have the targets and stops be measure against the new entry price, not join with existing orders. I prefer to manually move an order to the same stop if necessary, but for sure the targets will always be different.
Please advise.
Thank you
[2021-07-13 20:04:56]
John - SC Support - Posts: 38222
You have Scale In enabled. Disable this. Refer to the following:
Attached Orders: Scaling In
