Date/Time: Thu, 27 Feb 2025 14:59:06 +0000
M indicator after the symbol is missing on my sub instances
View Count: 444
[2021-07-13 16:59:43]
User149749 - Posts: 2
I am running SC-Data - All Service w/CME data and using AMP as my brokerage account to qualify for non-professional exchange fees. On my main chart, I have the M indicator after the ESU21-CME CB [M], telling me the Denali Exchange data feed is real time. When I do sub instance and load NQU21-CME, I get NQU21-CME [CB] without the M indicator. Should the M indicator be on the sub-instances? In the past, I believe I had the M indicator on my sub-instances.
I have re-read and stepped through the setup instructions for CME group exchanges and I still do not get M indicator on my sub-instances.
If the M is required, then I am doing something wrong and I would appreciate additional direction to help correct my issue. Regards, Bill Morgan
[2021-07-13 17:09:03]
John - SC Support - Posts: 38222
The [M] indicator will not show up in Sub-Instances as they are not getting the data directly from the data feed, rather they get the data from the main instance. As long as your main instance as the [M] indicator, then that data is coming from Sierra Chart.
