Date/Time: Thu, 27 Feb 2025 14:55:36 +0000
Multiple Data Feeds when using Sierra Trading Evaluator service?
View Count: 551
[2021-07-12 22:41:20] |
User275839 - Posts: 61 |
Hello - I am subscribed to both the Denali feed and the Sierra Chart Real-Time and Historical Exchange Data feed (250 symbols, US Equities). For my Data/Trade Service I am using the Sierra "Trading Evaluator" service. It appears that the Sierra Chart Real-Time and Historical Exchange Data Feed is NOT available (via "Find Symbol") when using the Sierra "Trading Evaluator" backend. Is that the case? If so, how can I access both Denali and Sierra Exchange feed data AND continue to do simulated futures trading using the Sierra "Trading Evaluator" backend? Please advise. Thank you! |
[2021-07-13 14:22:29] |
John - SC Support - Posts: 38222 |
Yes, it is correct that when connected to the Trading Evaluator Service that you only have access to those symbols that can be used with the Trading Evaluator. Therefore, the best way to handle this is to have a second installation of Sierra Chart and set the File >> Data/Trade Service Settings >> Current Selected Service to SC Data - All Services. Then you will have access to all the data in that second instance. Refer to the following for information on how to install a second Sierra Chart: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
