Date/Time: Thu, 27 Feb 2025 12:47:53 +0000
Rectangle drawing tool
View Count: 750
[2021-07-12 17:31:09]
User575399 - Posts: 326
Is it possible when using the rectangle drawing tool to make the rectangles the same size every time with one click instead of comparing the size to my other rectangle drawings? I know it sounds petty, but I use the same size rectangle drawings all day long. Thanks!
[2021-07-12 18:14:33]
John - SC Support - Posts: 38222
There is not a way to do this using the built-in options in Sierra Chart.
You could accomplish this by creating a custom study and capturing your starting point by the study and then drawing the rectangle from that point using your standard size each time. Refer to the information on creating a custom study using ACSIL starting here:
Advanced Custom Study Interface and Language (ACSIL): Introduction
And, just so you are aware, there are options in the Rectangle Configuration to define the Start and End times. Refer to the information here:
Chart Drawing Tools: Rectangle | Extending Rectangle | Ellipse | Triangle Configuration
