Date/Time: Thu, 27 Feb 2025 12:53:41 +0000
Morningstar Forex
View Count: 492
[2021-07-12 16:20:18] |
The Pipe - Posts: 16 |
I want to subscribe to Live Morningstar Forex. First the trial and the $21 a month subscription. For some reason I cannot when I go to active it stops and says at least one active data feed is required. I want live forex data from morningstar and future data can be delayed. How would I change it to receive the live forex data from Morningstar? Thank you!
[2021-07-12 17:12:51] |
John - SC Support - Posts: 38222 |
You need to go through all the Setup Instructions for the Sierra Chart Exchange Data Feed in order to get the data. You will find the instructions here: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
