Date/Time: Thu, 27 Feb 2025 15:00:31 +0000
Looking for MCLEQ21 data
View Count: 573
[2021-07-12 04:02:14] |
washingtonb - Posts: 5 |
I cannot find MCLEQ21 data for Micro Crude Oil. Does the Denali feed for Sierra Chart have this data available?
[2021-07-12 07:15:37] |
This is now available. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-07-12 18:29:48] |
User750920 - Posts: 280 |
Cannot find it even after updating Symbols and disconnecting and re connecting. Where would it be located.. Under Futures Nymex or Futures CME. I have checked both and it is not there. Tried searching too.
Date Time Of Last Edit: 2021-07-12 18:31:47
[2021-07-12 18:55:09] |
John - SC Support - Posts: 38222 |
The symbol has not been added for the Sierra Chart Order Routing Service yet. We will get to this shortly.
[2021-07-13 00:17:50] |
Thank you for your quick response. Is there an ETA as to when we can expect this symbol?
[2021-07-13 02:42:13] |
MCL has now been added for the Sierra Chart Order Routing Service. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings But we have not updated all of the servers yet. So it cannot be traded until tomorrow evening. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-07-13 02:42:36
