Date/Time: Thu, 27 Feb 2025 15:28:23 +0000
Daily Chart
View Count: 612
[2021-06-30 16:15:18]
User841604 - Posts: 20
Greetings,
Daily bar chart are not being graphed correctly in the last month of the chart
How can I fix this ?
Thank you...
https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=52320
[2021-06-30 19:33:49]
John - SC Support - Posts: 38223
Monday May 31, 2021 was a holiday in the US.
[2021-06-30 21:16:54]
June bars are not displaying on the daily chart
imageDaily.png / V - Attached On 2021-06-30 21:13:49 UTC - Size: 170.48 KB - 180 views
imageDaily.png / V - Attached On 2021-06-30 21:16:21 UTC - Size: 170.48 KB - 172 views
[2021-06-30 21:24:45]
Ahhh, sorry, we were looking at where the arrow was specifically pointed.
The first thing we want you to do is to go to Chart >> Chart Settings >> Advanced Settings >> Continous Contract and set that to None. Then select the Insert button to reload and recalculate the chart and see if the data gets filled in.
[2021-07-01 16:07:01]
Changed to none, but still doesn't work...
Something curious... With crypto works fine...
[2021-07-01 18:27:08]
Then the next step is to follow these instructions:
https://www.sierrachart.com/index.php?page=doc/helpdetails6.html#h6.3
[2021-07-13 14:26:40]
I am using version 2100, I can't upgrade because I am using indicators that don't work on higher versions.
The version seems to be the issue
Is there any way to solve without upgrading ?
[2021-07-13 16:18:29]
Unfortunately no, you are going to need to update to the current release. There have been changes to how the historical data is handled and it requires that you are on a current release.
