Date/Time: Thu, 27 Feb 2025 08:18:10 +0000
Spreadsheet range in a formula?
View Count: 520
[2021-06-29 16:23:53] |
owendonk - Posts: 54 |
Is it possible to do something like this but for 1000+ rows without manually typing it all out? =AND( AND(ID0.SG4@3<P3), AND(ID0.SG4@4<P4), AND(ID0.SG4@5<P5), AND(ID0.SG4@6<P6), AND(ID0.SG4@7<P7), AND(ID0.SG4@8<P8), AND(ID0.SG4@9<P9), AND(ID0.SG4@10<P10), AND(ID0.SG4@11<P11), AND(ID0.SG4@12<P12), AND(ID0.SG4@13<P13), AND(ID0.SG4@14<P14), AND(ID0.SG4@15<P15), AND(ID0.SG4@16<P16), AND(ID0.SG4@17<P17), AND(ID0.SG4@18<P18), AND(ID0.SG4@19>P19)) I need to do this to count a minimum duration of a crossover being maintained (note 19> instead of <). I have several other general uses in mind for this if possible. Date Time Of Last Edit: 2021-06-29 16:42:16
[2021-06-29 17:05:38] |
John - SC Support - Posts: 38222 |
There is no method to automate this kind of entry within the Spreadsheets within Sierra Chart.
[2021-06-29 17:48:05] |
I figured out a way in google sheets if anyone else needs a solution. See the screenshot. Just split it up into junks that can be autoincremented with a drag down, concatenate, then drag it down to autofill it.
Date Time Of Last Edit: 2021-06-29 17:48:20
