Date/Time: Thu, 27 Feb 2025 08:30:37 +0000
How to get live Denali Data Feed
View Count: 578
[2021-06-28 20:36:36]
warrenwma - Posts: 7
I am getting delayed data and need to connect to Denali Data Feed.
YM (mini DOW) trades on the CBOT, the ES (mini SP) trades on the CME, and the RTY ( mini Russell 2000) is on the CME.
[2021-06-28 21:06:19]
John - SC Support - Posts: 38222
The first thing you need to be aware of is the requirement of the CME Group that you have a live, funded, futures trading account in order to qualify for the lower-priced non-professional exchange fees. For more information, refer to the following:
Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges
If you do not have an account, then we recommend the following:
Easy Solution to CME Funded Trading Account Requirement
Once you know how you are going to handle the above issue, then follow these instructions to setup the Denali Exchange Data Feed:
[2021-06-28 22:16:56]
I am still getting delayed data despite doing everything to enable live Denali Data Feed. Also, the Sierra charts (ver 2280) are still in Sim mode. What do I have to do to get this thing going correctly?
[2021-06-29 13:18:50]
Both questions are related to the same thing. You need to connect to your futures trading account. What broker are you using and do you know what order routing service they are using (CQG, TT, Rithmic, etc.)?
[2021-06-29 14:39:33]
Thank you, John. I am having a broker connection problem that may be causing this problem. I should be able to connect to Denali once this is resolved. The broker is Infinity, now Ninja, I believe, and actually trades through TransAct Futures. I do apologize for taking up your time and hope not to bother you again. Once I am connected to SCs, everything goes very well. WAW
[2021-06-29 16:22:22]
If you will be using TransAct for your orders, the follow these Setup Instructions to connect your Sierra Chart to your TransAct account:
https://www.sierrachart.com/index.php?page=doc/TransAct.php#SetupInstructions
