Date/Time: Thu, 27 Feb 2025 08:38:20 +0000
No Chart Data with CQG
View Count: 564
[2021-06-28 19:25:23]
User433334 - Posts: 2
After my holidays (end of may until mid of june) my CQG Date connection is not working anymore with Sierra. I am getting 2 messages within my chart windows: 1.symbol unkown (same symbols are used as before ) and 2. download data failed. I updated my SC Version on 2280. I did no changes of login credentials in my CQG account...
Sierra is working but can not interpete CQG feed anymore. It works with SD feed delayed. I heard that there were problems SC /CQG...?
[2021-06-28 20:04:42]
John - SC Support - Posts: 38222
The implication from what you describe is that you are not setup to receive the CQG data. Check with your broker and ensure that your CQG data feed is enabled.
[2021-06-28 21:41:10]
Sierra_Chart Engineering - Posts: 18584
When using CQG you need to use the Denali Exchange Data Feed for data:
You have set the Service Package correctly but you need to activate the exchanges that you require here:
https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeedEUREX
