Date/Time: Thu, 27 Feb 2025 08:13:17 +0000
replay issue
View Count: 432
[2021-06-28 14:18:58] |
blackcobra777 - Posts: 28 |
i have some issue while playing replay futures they cant work correctly i delete download data and redownloaded it too but can't work every chart perform different than others even all have the same link etc i attahced a pic of my replay see this and tell me what should i do next? to fix this i try all things replay works on currencies good but when i use in futures i get this problem |
[2021-06-28 16:02:53] |
John - SC Support - Posts: 38222 |
Refer to the following: Replaying Charts: Preventing Loss of Synchronization Between Different Charts During Replay There is also useful information in the section above this. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
