Date/Time: Thu, 27 Feb 2025 08:08:12 +0000
small Quote Board bug
View Count: 527
[2021-06-27 09:41:12] |
aknsyu71@gmail - Posts: 54 |
Using the Quote Board: When changing a header label by right clicking on label and choosing "Change Header Label" the change is not applied untill the chartbook is closed and opened again. Date Time Of Last Edit: 2021-06-27 09:42:04
[2021-06-27 21:47:35] |
This will be resolved in the next release.
[2021-06-28 15:46:57] |
User90125 - Posts: 715 |
+1 When changing a header label by right clicking on label and choosing "Change Header Label" the change is not applied untill the chartbook is closed and opened again.
A fix for this is long overdue. Thank you. |
