Date/Time: Thu, 27 Feb 2025 08:36:36 +0000
I have added bid and ask lines to my charts
View Count: 822
[2021-06-25 16:09:55]
User644439 - Posts: 13
I have added bid and ask lines to my charts but they are only small lines on the axis, how do i extend them across the chart, thanks.
Regards,
Conor.
[2021-06-25 16:34:19]
TriStar Trading - Posts: 148
Set the drawstyle on the subgraph to Line from end of chart left to right
[2021-06-25 17:06:54]
John - SC Support - Posts: 38222
If you really want the line to go all the way across the chart, then add the study Bid & Ask Prices to the chart and then set the Subgraphs for that study to Line at Last Bar from Left to Right as suggested above. Refer to the following for the study:
Bid & Ask Prices
And refer to the following for the Draw Style:
Chart Studies: Line at Last Bar Left to Right (ACSIL: DRAWSTYLE_LINE_AT_LAST_BAR_LEFT_TO_RIGHT)
Note that there are other draw styles that may be what you prefer, such as Line at Last Bar to Left Edge, which would not draw the line in the Forward Projection Area. If one of these is not what you want, then look around at the other options.
[2021-06-28 13:14:07]
where can i find this option?
[2021-06-28 15:08:41]
The Draw Style is part of the Subgraphs tab for a study. Refer to the following:
Chart Studies: Subgraphs Tab
