Date/Time: Thu, 27 Feb 2025 05:25:49 +0000
Lines arent on point
View Count: 379
[2021-06-21 06:23:10]
User562957 - Posts: 58
Hello, I opened SC and on friday everything worked good, but now there is the problem that my lines in the chart arenĀ“t exactly you see it on the picture the same thing is to my trading dom. In the chart I want the red line on the open on the third candle you see it ? it doesnt go there it do the flip upwards or downwards it mean i cant do the trendlines exactly and in the dom there is the chaos. I got the current version 2276 from sc so can you help me ?
imageProble,.png / V - Attached On 2021-06-21 06:20:40 UTC - Size: 46.93 KB - 179 views
imageProblem2.png / V - Attached On 2021-06-21 06:21:15 UTC - Size: 22.88 KB - 174 views
[2021-06-21 06:38:17]
Sierra_Chart Engineering - Posts: 18577
And then follow these instructions to apply these settings to these charts:
Global Symbol Settings: Update/Apply Symbol Settings to Charts
