Date/Time: Thu, 27 Feb 2025 05:04:04 +0000
Global settings not transferring
View Count: 435
[2021-06-21 05:52:03] |
mc8909 - Posts: 5 |
Hi, a SC user sent me his chartbook but the global graphic settings aren't transferring over. Chartbooks from other users have been fine but not the one from him. Please advise, thanks
Attachment Deleted. Private File Private File |
[2021-06-21 06:25:53] |
Sierra_Chart Engineering - Posts: 18577 |
The global graphics settings are in the Sierra4.config file. They can send that file to you. Refer to: File Sharing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
