Date/Time: Thu, 27 Feb 2025 04:58:23 +0000
DOM Problems
View Count: 567
[2021-06-21 05:40:39]
User565974 - Posts: 32
Hi Guys,
since today morning, my DOM EuroSXX50 is unusable, also since couple of weeks the chart (EuroStxx50) displays format 0.1 - I couldn´t find anything at EUREX about change of product in the EuroStxx50.
SC DOM/Chart displays tick size of 0.5!? I´ll send a screenshot of chart and DOM.
Please let me know if EUREX made any change - as mentioned above I couldn´t find a change in product!
imageDOM_SXX_Problem.png / V - Attached On 2021-06-21 05:38:04 UTC - Size: 305.07 KB - 181 views
imageChart_SXX.png / V - Attached On 2021-06-21 05:38:17 UTC - Size: 154.79 KB - 172 views
[2021-06-21 05:47:57]
AD544 - Posts: 64
https://www.eurex.com/ex-en/find/circulars/circular-2407638
[2021-06-21 05:57:36]
My last inquiry is solved - it seems the eurex has changed the FESX product from tick size 1 to 0.5!
Nontheless there is still a problem with the DOM...
Send the screenshot
imageDOM_SXX_Problem2.png / V - Attached On 2021-06-21 05:57:24 UTC - Size: 291.6 KB - 186 views
[2021-06-21 06:17:27]
Sierra_Chart Engineering - Posts: 18577
The tick size for this product changed. We have done the updates now, including the changes on the server.
Be sure to re-connect to the data feed also.
[2021-06-21 06:29:31]
Bango - Posts: 76
Errors on populating asks. Many numbers on 4-5 prices
[2021-06-21 06:39:12]
thanks, solved
[2021-06-21 06:39:40]
If you are still having problems do the following:
And then follow these instructions to apply these settings to these FESX charts:
Global Symbol Settings: Update/Apply Symbol Settings to Charts
Date Time Of Last Edit: 2021-06-21 06:40:41
