Date/Time: Thu, 27 Feb 2025 05:15:37 +0000
FESXU21 DOM not correct
View Count: 513
[2021-06-21 05:34:28]
Bango - Posts: 76
Hello, DOM data on FESXU21-EUREX are not correct. Bids seem right, but only 5 levels on the ask side well below the best bid!
No problem on others Eurex products though.
imageFESXU21DOM.png / V - Attached On 2021-06-21 05:31:22 UTC - Size: 30.09 KB - 187 views
[2021-06-21 05:51:01]
AD544 - Posts: 64
EUREX changed tick size from 1 to 0.50
SC has not yet updated this change
https://www.eurex.com/ex-en/find/circulars/circular-2407638
[2021-06-21 06:16:46]
Sierra_Chart Engineering - Posts: 18577
The tick size for this product changed. We have done the updates now, including the changes on the server.
Be sure to re-connect to the data feed also.
