Date/Time: Thu, 27 Feb 2025 05:18:23 +0000
Large Volume Indicator Improvement Request.
View Count: 461
[2021-06-19 15:37:14]
MindPortal - Posts: 18
Very much appreciate that sierra added the large volume indicator. It would be a huge improvement if the text was centered on the candle and it was displayed above/ below the wick instead of obstructing the candles. This would be great as well for the circles. Thank you
image2.PNG / V - Attached On 2021-06-19 15:23:49 UTC - Size: 32.72 KB - 191 views
image3.PNG / V - Attached On 2021-06-19 15:37:04 UTC - Size: 19.98 KB - 199 views
[2021-06-21 14:34:00]
John - SC Support - Posts: 38222
The Large Volume Trade Indicator has a number of options to allow you to place the value anywhere you want it when you are looking at a single value for the entire bar. In particular, note these three Inputs:
- Marker Alignment
- Entire Bar Marker Vertical Alignment
- Entire Bar Marker Vertical Offset in Ticks
