Date/Time: Thu, 27 Feb 2025 05:02:07 +0000
moving average amaud legoux not displaying
View Count: 500
[2021-06-18 23:56:45] |
Don H - Posts: 31 |
When adding amaud legoux moving average to studies it does not graph or display on chart
[2021-06-21 14:24:48] |
John - SC Support - Posts: 38222 |
You need to update to the latest version. That was an issue with an early release that did not work properly. You can update using these instructions: Software Download: Fast Update For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
