Date/Time: Thu, 27 Feb 2025 04:54:27 +0000
EURO STOXX 50 (FESX) - tick change from 21 June 2021
View Count: 1125
[2021-06-16 11:45:20] |
User365411 - Posts: 192 |
Only a reminder for the SC staff and FESX traders The Board of Management of Eurex Deutschland has decided to reduce the smallest price change (tick) in outright contracts of EURO STOXX® 50 (FESX) Index Futures with effect from 21 June 2021. The new tick will be 0.5 index points (currently: 1.0 index points). The tick value will be reduced from EUR 10 to EUR 5. https://www.eurex.com/ex-en/find/circulars/circular-2407638 Date Time Of Last Edit: 2021-06-16 11:45:50
[2021-06-16 14:25:40] |
John - SC Support - Posts: 38222 |
Thank you.
[2021-06-21 08:00:19] |
User90125 - Posts: 715 |
Reminder for SC Engineering and EUREX traders on FESX today, as above. The appropriate Global System Settings should be updated accordingly, as the FESX data is now trading with the new tick size already. Date Time Of Last Edit: 2021-06-21 08:37:36
[2021-06-21 09:39:15] |
Sierra_Chart Engineering - Posts: 18577 |
Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings After that apply the settings to FESX charts: Global Symbol Settings: Update/Apply Symbol Settings to Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-06-21 09:39:50
