Date/Time: Thu, 27 Feb 2025 04:22:14 +0000
GRAPHIQUE
View Count: 538
[2021-06-15 08:14:15]
REMI MILANDE - Posts: 10
BONJOUR JE RENCONTRE DES DIFFICULT2 PAR RAPPORT A MON GRAPH 1 MIN COMME VOUS POUVEZ LE CONSTATER SUR LA PHOTO AU NIVEAU DES BOUGIE J4AI DEUX CHOSES QUI ME GENE LA PREMEIERE LES CHIFFRE AU DESSUS ET EN DESSOUS DES BOUGIE, et les colonne de droite et de gauche autour des bougie qui a mon avis corresponde a du carnet ordre pouvez vous aider a les masquer qu'elle est la marche a suivre je suis allez dans les studise mes sans resulta .
HELLO I AM ENCOUNTERING DIFFICULT2 COMPARED TO MY 1 MIN GRAPH AS YOU CAN SEE ON THE PHOTO AT THE LEVEL OF THE CANDLES J4 HAVE TWO THINGS THAT GENERATE ME THE FIRST NUMBERS ABOVE AND BELOW THE CANDLES, and the right and left columns around the candles which in my opinion correspond to the order book can help you hide them that it is the procedure I am going to study my without results.
mon mail milande0726trading@gmail.com
[2021-06-15 14:55:51]
John - SC Support - Posts: 38222
There is not an image posted. Can you please post an image so we can understand better what you are looking for.
