Date/Time: Thu, 27 Feb 2025 02:29:35 +0000
[User Discussion] - Daily OHLC study or Study Subgraph Reference bug possibly
View Count: 507
[2021-06-14 23:57:53]
58LesPaul - Posts: 429
When a new day starts at 18:00:00 my Daily OHLC study has the vertical line from where the High and Low changes for the new day. I also have the Study Subgraph Reference set for these and Draw Zero's set to No. I open the Studies Window and click OK which closes the window and the vertical lines disappear. If I select Cancel instead of OK, the vertical lines stay on the chart.
[2021-06-15 09:24:53]
IDK why this was changed to User Discussion, I was wanting SC to look into it.
[2021-06-15 10:57:57]
User907968 - Posts: 833
What is your draw style set to for Daily OHLC?
[2021-06-15 11:52:54]
It is set to line on the Daily OHLC study.
[2021-06-15 12:15:39]
Ok, so to remove the vertical lines, try using dash instead.
[2021-06-15 12:24:17]
Thanks but why do they show up at the start of a new session and just opening the Study Window and selecting OK to close the window cause the vertical lines to disappear? It sounds like a bug to me. I will try dash and see it that stops it.
