Date/Time: Thu, 27 Feb 2025 02:28:20 +0000
Update installation does not work
View Count: 428
[2021-06-14 19:46:08]
User905210 - Posts: 3
After running the download it says:"Error saving the downloaded files to local system. Stopping installation. Check log."
Could you please give me a hint what to do? Thanks!
[2021-06-14 20:45:38]
John - SC Support - Posts: 38222
Here is the error from your Installer Log:
Error writing to file: C:\SierraChart\DownloadedInstallationFiles\SierraChart_64.exe. Error: Windows error code 112: Es steht nicht genug Speicherplatz auf dem Datenträger zur Verfügung.
This error states that there is not enough disk space available. So you would need to free up some disk space in order to perform the installation.
Refer to the following for help with clearing out disk space related to Sierra Chart:
Chart Data and Chart Data Files: Cleaning Up Old and Unused Symbols for Efficiency
In particular, note step 7 in the above that gives you the information for deleting the files.
