Date/Time: Thu, 27 Feb 2025 02:25:02 +0000
switch from CQG to DENALI data feed
View Count: 804
[2021-06-14 16:32:05]
MightyTulip - Posts: 5
Hi, I would like to use the market replay feature so I can practice trading on the DOM. However, I have discovered that I cannot see market depth using CQG data. I would have to use the Denali Data feed. Is this correct? If so, how can I go about changing to the Denali feed.
Another question, I started out using the Denali data feed, but there was an execution error while I was trading and sierra chart suggested switching to the CQG data feed to solve the problem. I cannot use the market replay and see market depth data while using CQG, so my question is, do you think it is safe to switch back to the Denali data feed and continue trading? I would really like to use the replay feature with market depth to practice execution on the dom while replaying important moments from the previous trading day. thank you.
[2021-06-14 18:28:28]
John - SC Support - Posts: 38222
First, you should be able to see the Market Depth data even though you are using CQG for your data. Whatever Market Depth data you are getting in Real-Time just has to be recorded in order to ensure that it is saved for when you want to run a replay. For more information, refer to the following:
Replaying Charts: Replaying of Market Depth Data
Second, it would be very surprising if we told you to switch from the Denali Exchange Data Feed to CQG. We state the opposite all the time, as we want people to have the best experience with Sierra Chart and we know that our data feeds will provide what is needed.
Therefore, if you want to switch back to the Denali Exchange Data Feed, there should not be a problem. In addition, by doing so you will also have access to 1400 levels of Market Depth for the CME Group symbols and you can download missing historical market depth data for the past 30 days. For more information on downloading the historical market depth data, refer to the following:
Market Depth Historical Graph: Downloading Of Historical Market Depth Data
In order to enable the Denali Exchange Data Feed, follow these instructions:
