Date/Time: Thu, 27 Feb 2025 02:09:46 +0000
data package preferred?
View Count: 435
[2021-06-14 16:20:00] |
User725043 - Posts: 38 |
Hi, Trying to figure the best package for trading intraday the Nasdaq-100 emini on the CME (NQ). I also need US equities, (NYSE, NDAQ, AMEX). Is there a preferred package that you recommend? How much would the total cost be? If I also run the Trade Execution through SC, are there any additional charges? If yes, how much? Thanks |
[2021-06-14 18:19:35] |
John - SC Support - Posts: 38222 |
In terms of packages, it depends on what you need in order to support your trading. You will find the differences in the packages (including their pricing) on this page: Description of Service Packages and Pricing: Packages If you want to get the data from us, the first thing to be aware of with regards to the CME Group data (NQ) is that you need to have a live, funded, futures trading account in order to qualify for the lower priced non-professional exchange fees. Refer to the following for more information: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges Given the above, in order to use the Denali Exchange Data Feed, you will follow these instructions: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* For the U.S. Equities data, you would need to use the Sierra Chart Exchange Data Feed. You will find the Setup Instructions for this here: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions The costs for the data are laid out on each of the pages referenced above where the Setup Instructions are. In general there are no extra fees for trade execution through Sierra Chart. But, if you use the Sierra Chart Order Routing Service, then there is a $0.10 per side order routing fee that is paid to us. Normally this is paid through your broker and then to the order routing service. So it's not really an additional fee, but is just paid to a different source. For more information on the Sierra Chart Order Routing Service, refer to the following: Sierra Chart / Trading Technologies Futures Order Routing Service For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
