Date/Time: Thu, 27 Feb 2025 02:18:51 +0000
New Instance Not Working
View Count: 414
[2021-06-14 15:51:15]
User665364 - Posts: 1
I am logged into the charts.
I use Transact Futures.
The first instance of a chartbook comes up fine.
When I try to load a new instance I get message that says "invalid account or password."
Resetting password did not help.
Alex
imageScreenshot 2021-06-14 104506.png / V - Attached On 2021-06-14 15:49:41 UTC - Size: 42.65 KB - 164 views
[2021-06-14 18:09:13]
John - SC Support - Posts: 38222
Completely exit from all instances of Sierra Chart. Then start Sierra Chart again and use the Forced Login option. Refer to the following:
Sierra Chart - Software Login Instructions: Forced Login
Then start the new instance and see if you continue to have an issue.
